AutoCAD file import to ArchiCAD
Hi there,
Is there a function in ArchiCAD so that you can assign layers from AutoCAD to wall objects or roof objects in ArchiCAD.
Thanks
Pieter
1 Reply 1
Link
Sure.
Go to File>File Special>DXF-DWG Translator Setup... Then set up a new translator and create New conversion items via the Attribute>Layers>Layer name conversion area of the Settings in Selected Translator panel.
Link.
