Ricardo Lopez
Best practice to import a massive amount of typical 2d DWG details
Hi
I know how to import DWG files, even how to translate their attributes (mostly) to Archicad, but what if I have a huge collection of 2D DWG details and I need to have them all available at any time outside my template.
What will be the best practice to maintain that collection in a collaborative environment in a healthy way?
Suggestions are welcome.
Thank you in advance.😊
Ricardo López, M. Arch.
3 Replies 3
Davor P
Hi Ricardo
"Typical details" teamwork project perhaps? Make sure attributes are aligned between the template and this file and there should be no issues in copying between them.
I would add one dwg to one worksheet.
You can publish all to pdf for user convenience.
BIM4BIM - by BIM managers for BIM managers
www.bim4bim.com | audit.bim4bim.com
Hi @Ricardo Lopez,
For this case I use (Place external drawing) function so I can control visible/invisible layers, pens&colors without affecting my file attributes, all DWG details will be imported to (Drawing & Figure) layer.
AC 29 INT 4006/WIN 11
Ricardo Lopez
Has anyone ever worked with a master detail file and posted PMK files or something similar?
