Got a minute? We appreciate your feedback:
Graphisoft Learn survey
Best way to convert archiCad model to counterstrike level
Hello Everyone,
I have a very relevant question. What is the best way to convert a archicad model to a counterstrike level?
5 REPLIES 5
runxel
Legend
I doubt this is a "relevant" question in a forum where one would actually expect all users to be architecture professionals.
It's still an interesting and funny question, tho.
First of all, you're basically saying you want creating stuff for use in the Source Engine. In this case maps are created using the "Hammer Editor" by Valve. Worlds/Levels made there are "brush" based – a special technique not found in a CA(A)D. (Of course, since the requirements are very different.)
Thus, Hammer can't load external 3D formats.
That being said, there is a still a cumbersome way to do it.
There are plugins for 3DsMax and Sketchup.
You than can either directly export .vmf (Valve Map Format) for maps itself, or .dmx for any props (like cars/people/etc.).
With a lot of energy and time (you somehow need to bring your Archicad model to the other applications first, then repairing the errors resulting from exporting and lastly make needed adaptions (e.g. concave topology is forbidden in brush based engines)) it could be possible. But I highly question that this is making sense as well.
Lucas Becker | AC 27 on Mac | Editor at SelfGDL | Developer of the GDL plugin for Sublime Text |
«Furthermore, I consider that Carth... yearly releases must be destroyed»
Erwin Edel
This reminds me that my first 'CAD' was done using Doom Editing Utilities for DOS
Saving out to sketchup is easy enough with ArchiCAD, but you'll have to prepare the model for export there and it will take quite some time no doubt.
BTW, if you go in to 3D perspective in ArchiCAD, hit explore and hold down F P S keys at the same time, you'll get a crosshair. Just imagine the guns and things and you have your FPS game
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
runxel
Legend
Nice one! DoomCAD
Next main feature of Archicad 22: Fully integrated Frostbite Engine to "enable large scale multiplayer interactions in dynamic destructible environments".
Wreck it before it's build!
Than you for a really good answer!
stefan
I remember when playing with the older version of the Unreal engine that BIM models are not the actual level models (brush based BSP) but can be inserted as "Static Meshes" (normally used for props, such as boxes, closets etc...).
I would assume this is similar in the Source engine.
community.foundry.com/discuss/topic/91506/source-engine-2-hammer-2-editor
Archicad26/Revit2023/Rhino7/Unity/Solibri/Zoom
MBP2023:14"M2MAX/Ventura+Win11
ARCHICAD-user since 1998
Archicad Book
