Eduardo Rolon
Calculate Volume
I had to help design a concrete column for a pier. This column has nothing regular about it (see image). I can import the SketchUp file into AC but my problem is that I need to calculate its volume. AC gives me the surface area but volume is 0.0.
Any help will be appreciated.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
3 Replies 3
Djordje
Shot in the dark - if it is a GDL object, try adding MODEL SOLID in the 3D script.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Eduardo Rolon
And I do that how?
Anyway I may have had found another way to do it with no GDL coding. If it works I will post it.
AC29 US/INT -> AC08
Aussie John
the element info pallette can be arranged to give volumes
Cheers John
[/size]
