Hi Dan,
Yup, you've come across another of the many wishes for the I.S.
There is a single-story workaround. If you select the elements you are interested in on a given story ... then only those elements are included in the schedule. So, you can use Find & Select (with marquee) to select those elements first...and save the F&S criteria.
The I.S. does not work from the 3D window, otherwise you could use F&S there as a workaround for what you were trying to do.
Just as a note to others: this select-first trick only works if you select the elements of the type you are scheduling. So, if you select a few windows, then invoke the I.S. for a window criteria, then only those selected windows appear. But, if you select the host walls that
contain
the windows, then things behave as if you have selected no windows and all windows in the model will be included.
Sigh.
One of the forum moderators
AC 27 USA and earlier • macOS Ventura 13.6.7, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
