Change order of lines on interactive Schedule?
This should be a simple question (...?) I'm creating an area schedule and and schedule reports:
ATTIC 770
LOWER FLOOR 1330
UPPER FLOOR 1291
But I would like to start from lower level up. Lower, Upper, Attic. I'm assuming order is alphabetic, is there any way to change the order of lines? If I revert alphabetic (assuming it is possible) It will do Upper, Lower, Attic, which is incorrect as well.
felcunha
You can't change the alphabetical order but you can add the number of the story in the schedule. You'll be able then to show them from bottom to top.
Felipe Ribeiro Cunha
AC 26, macOS Monterey
7 REPLIES 7
felcunha
Erwin Edel
Or list the story number and keep the names intact and sort by number.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
Thanks this helps. Is there any way to hide column on schedules? I mask them on layouts but was wondering if there is a way to hide or at least change font color to white just on a column (?)
Have you tried stretching the column width to zero or near zero?
I haven't tried and don't have Archicad open at the moment - but it might work.
Erwin Edel
You can't hide collumns, however you could have it as the last collumn and crop the placed view.
www.leloup.nl
That's what I do. ...wish list maybe?
There is already a wish for hidden fields in Schedules, cast your vote there:
https://community.graphisoft.com/t5/Wishes/Hidden-Fields-in-Schedules/td-p/138387?t=45133
