Ernest Atanasiu
Classification in Germany
Hello there.
Is anyone familiar with the classification system used in Germany?
I know the must have a DIN somewhere for BIM, could anyone point me in the right direction, please ?
I am looking for the equivalent of Uniclass, more specifically a XML file to import and use right away would be great .
thank you.
arch. ernest atanasiu
AC 10-29 INT/GER/FR on Win 11
5 Replies 5
runxel
I'm afraid there is nothing like that.
The closest you can get is DIN 276, I suppose.
I know some offices, which will organize around the "costs groups". But the DIN is not about BIM.
Ernest Atanasiu
Thank you.
This is surprising. Do you think Uniclass would work ? Is it compatible enough ?
Erwin Edel
https://www.vdi.de/technik/fachthemen/bauen-und-gebaeudetechnik/querschnittsthemen-der-vdi-gbg/koord... is this what you are looking for?
The first (and last) time I did some research into German building regulations and such I gave up. I'm glad that one potential trip across the border for that project was put on hold. Seems to be a LOT of local level stuff going on and it is not easy to find out. My German pretty much being Dutch with a thick accent doesn't help though...
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
runxel
uisanata wrote:
Thank you.
Well, nobody cares. Germany is pretty darn late with the BIM stuff.
Heck, there is still a majority of offices using DumbCad...
So, just use whatever suits you. Potential benefits are small, tho.
schagemann
A few years back we did an adaptation of our mACT - ARCHICAD template based on DIN276 (which btw is surprisingly similar to the Australian NATSPEC system).
Anyway yes there seems to be not much else to go by.
Btw. IMHO the only real thing to go by is to get your IFC classifications right - until GRAPHISOFT changes their mapping approach with the next version of ARCHICAD.
VKTRS | macinteract
Design Technology Managers - all on macOS | since AC 6
Archicad Framework > Smart Template 28
Smart Tree, Transmittal and Universal Label plus other smart GDL Objects
