Starting August 6, 2024, TLS 1.2 will be the minimum required protocol version for Graphisoft products and services that require an online connection. Learn more…
Composite Wall/Roof export in IFC in AC23 problem
Mario Sacco
I'm trying some tests exporting in IFC and importing again in AC23 using the "general parametric export":
- Composite wall with boolean operation/trim are always transformed in objects
- Profile walls with boolean operation/trim remain correct wall profile but windows transformed in objects
- Simple walls are translated correctly
- Composite roof are translated in objects
Instead in AC 22:
- Composite wall with boolean operation/trim are transformed in simple wall;
- Composite roof are correctly retransformed in composite roof.
It seems AC22 work better with basic setting.
I tryed to change setting without any improvements.
LINK PLN: https://drive.google.com/open?id=19UpG_Re5uLlJj0y1Oehy4m4238OvxcPN
LINK IFC: https://drive.google.com/open?id=1OX7nVY_tf7qNKAVEXsp_BUJkYCOoNN8C
MacBook M1 Max 64GB- OS X 12.2.1 - Archicad 27
https://www.archiradar.it/en/
A few settings changed between AC22 and AC23 for IFC Export and Import. Here is the playlist that talks about these changes:
https://www.youtube.com/playlist?list=PLnXY6vLUwlWW3MmRDthnX5yeVJY7NIw6H
If you were testing this with something like Solibri Model Viewer, what would you see? I sometime think that using ARCHICAD to test its efficacy or the validity of the translator I'm using isn't the best way to know that it's working.
I've spent a week going back and forth from my ARCHICAD workstation to a Revit machine and while my legs are tired, I finally got close to what I'm trying to achieve.
Think Like a Spec Writer
AC4.55 through 27 / USA AC27-5030 USA
Rhino 8 Mac
MacOS 14.5
Mario Sacco
My test started inside a model checker. This is the reason I came back in Archicad.
I used Solibri and BIMVision.
The composite wall not cut and the composite wall not cat are translated in different way.
The composite wall cut is complex with al the boolean operation calculated. I'd like to have a simple wall like the wall not cut, only information with a simple shape.
Obviously this is only an example of a large project I'm working on. I Want to give my public client a simple model in IFC to check.
My next check is try to open it in Revit.
