2005-11-25 02:13 PM
2005-11-26 12:58 AM
2005-11-26 05:27 AM
2005-11-26 07:14 AM
2005-11-26 02:21 PM
2005-11-26 03:44 PM
Achille wrote:This option will put the PM layout in AutoCAD's model space and there will be nothing in PaperSpace. This was the traditional way of working in AutoCAD R10 - R14 because even though AutoCAD introduced PSpace in R12 it did not start to get widely used until AutoCAD 2000. Dimensions will work fine the difference is that when you plot from AutoCAD with everything in MSpace you have to choose the drawing scale. The problem with this approach is that the drawings on this sheet all have to be at the same scale if not some drawings will have to be rescaled and the dim settings for those dwgs will have to be configured properly to reflect this (which the AC translator does). The AC equivalent for this option is when you do everything in AC and do not use PM for plotting or view handling.
so you to get an empty model space if saving with the first option "model space with cropped drawing content"?...
2005-11-26 07:19 PM
2005-11-30 09:20 PM
Achille wrote:It does exist in the 8.1 Translator, that is included in the 9 installation. You have to activate it manually.
So the option "paper space with cropped drawing content" (the first of the three) doesn't exist... or it should be renamed "paper space with empty model space" and it is absolutely useless as it can be used only for plotting, were pdf is by far more a better option.
2005-12-01 11:01 AM
2005-12-02 09:48 AM
Achille wrote:Load it as an AddOn. Go to AddOn Manager, find it in the C:\Program Files\Graphisoft\ArchiCAD 9\Goodies\DXF-DWG 2K In-Out folder, load it.
please Djorge tell mh how!?!?!?!![]()
