Also, the Graphic List Schemes, even though capable of producing a report such as you show,  are static reports - and you wanted it to be interactive.
An interactive schedule can show "Records by Column" - and then with custom fields, can fill in most of the data you show.  But, it cannot show the info in the top left corner, nor the yellow subheading, etc.
So, I guess the answer is "no it is not possible".  The best you can do is a "by column" schedule that shows the data you want, even if the format is not identical.  I also do not believe that improvements in this area are on Graphisoft's radar - more pressing fish to fry.
Except for the graphic symbol, any schedule can be exported to CSV/Excel (and a Publisher set can export multiple schedules) and you can reformat externally as desired - for example, in database program with report-writing abilities such as Access or Filemaker - and then save a PDF of the schedule from there to be placed in your layouts.
