‎2005-09-20 10:08 AM
‎2005-10-13 01:21 PM
‎2005-10-13 02:28 PM
‎2005-10-13 04:41 PM
TomWaltz wrote:For Model Space, sure.
That said, I translate from Archicad most of the time, because I found it more consistant and reliable than Plotmaker translations.
‎2005-10-25 03:44 AM
Although you seemed to have ruled out the fills issue, I've experienced similar problems with large .dwg file sizes which I solved by playing around with the fills.Haneef, I have turned all fills off and I have not used any of customised fills at all. So I am assuming this is not a problem.
another thing worth checking is whether PM was set for "real line weights" or "hair lines" when you exported. That can make a huge difference, since "real line weights" translate at actual line weights in AutoCAD.Tom, the actual difference having true weights on and off was 800Kb +/- respectively.
Then you XRef into the PlotMaker export? Or what?...and exactly, then you're stuffed - without titleblocks and issue letters...
