2007-11-30 11:25 AM
2007-11-30 06:02 PM
2007-11-30 06:34 PM
2007-11-30 07:09 PM
another Moderator
2007-11-30 07:20 PM
2007-11-30 11:55 PM
ejrolon wrote:At home now, I'll test that tomorrow. I know it's a text file, but like HTML I thought it had to be formatted in some special way to be interpreted as XML.
Have you tried just changing the extension to XML intead of txt. AFAIK a XML file is just a text file.
2007-12-01 12:06 AM
Brad wrote:I thought so but it didn't work when I tested. It seems Autocad Styles are not equivalent to Fonts. (But then, why have the ability to translate styles to fonts? Or is it
I'm on 10 and I don't know about the txt file but can't you just set the font in the Font-style conversion window in the DXF-DWG Translation Setup? I've done it before with success.
2007-12-01 12:09 AM
another Moderator
2007-12-01 12:41 AM
Software make our life easier… perish the thought.What I'd really like is the person at Graphisoft who is responsible for this chapter to come forward and explain. Or at least point to some more thorough documentation of the process.
2007-12-02 11:32 PM
