2008-11-06 06:34 PM
2008-11-06 06:41 PM
The LTScale variable used in DWG files will now be correctly interpreted when opening or merging DWG files in ArchiCAD. New line types will be created as needed, regardless of the length of the original line pattern.Cheers,
2008-11-06 06:45 PM
2008-11-06 08:20 PM
Laura wrote:This is the trick that I have used since AC8 when I have to explode or merge a dwg.
I'd like to place the DWG as a Drawing (as opposed to Xrefing or Merging) to avoid contaminating the AC file with a bunch of useless attributes. Your suggestion does give me an idea, tho -- Merge the file into a separate instance of AC, and placethatfile as a Drawing...
another Moderator
2008-11-07 12:26 AM
Karl wrote:AFAIK, LTscale translation should work with Drag-and-drop (Place External Drawing is the same) as well as Open or Merge in AC12. Only Xref does not handle linetype scales well.
I seem to recall some discussion by various testers during beta that the linetype scale interpretation (LTSCALE) improvement in 12 may only work with a file Open or file Merge....
2020-11-18 03:57 PM
2020-11-22 02:41 PM
2020-12-08 09:54 AM
2020-12-08 10:09 AM
Sculptdesign wrote:
I just want to make this one linetype a larger scale without changing anything else. Is this even possible?
2020-12-08 10:27 AM
