ā2004-02-27 12:53 AM
ā2004-02-27 08:18 AM
KeesW wrote:Go to Tools/DXF-DWG Translation Setup and change the Translator settings as needed before opening the DXF.
I've loaded Archicad v8.1 and am needing to import a DXF drawing. Unfortunately, my translator attributes do not include 'Fills (save methods)" as described in the Archicad User Guide Vol 2 page 150.
Is there a setting I've missed?
ā2004-02-28 05:55 AM
ā2004-02-28 06:20 PM
KeesW wrote:How are your fills set? If it is bitmap, you will not see anything when you open DXF or DWG. You need vectorial fills on in your Display options.
Thank you Djordje. It was set correctly in Tools. There must be a problem with the DXF file I was given. the client's hard copy showed fill, but her DXF copy of the same drawings do not.
ā2004-02-29 04:25 AM
ā2004-02-29 06:43 PM
KeesW wrote:Hmmmm ... do you see an X with a line starting from the middle of it left or right approximately where the center of the fills should be?
Djordje
Thank you again. Options ARE set on vectorial fills but it still doesn't show. I'll get my client to check her file.
ā2004-03-01 12:11 AM
