Dimensions in Schedules
Does anyone know of a way to get rid of the zeros int eh dimension under glazing in the attached pdf.
7 REPLIES 7
David Maudlin
Brad:
After creating a View of the schedule, you can open its settings and assign a Dimensions Standard, as you can with other Views.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
I agree with that but I do not see a dimension setting in the preference>dimensions dialogue box that allows dimension to be shown as 5/8" instead of 0'-0 5/8".
Erika Epstein
Options>Project Preferences>Dimensions
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
jbArch
Erika beat me to it, but I think it is worth noting that you need to check TWO radio buttons correctly. See attachment.
JB
AC 21 (8002) & 22 USA
Mac OSX 10.14.5 on MacBook Pro 2.3GHz Intel i7, 16GB Ram, NVIDIA GeForce GT 750M 2GB VRAM, 500GB SSD
David Maudlin
Brad:
I took a look at this in ArchiCAD 12 & 13, and found that only the second column under Display of Zero Feet & Inches has any effect in Interactive schedules. The other options work for linear dimension in the Floor Plan, but do not work in the schedules. So you can eliminate the zero for full inches, but not for feet. Looks like a bug.
David,
I came to the same conclusion.
Brad
I am still getting this bug eight years later in AC20 USA 5025, exactly as described in the last comments. Is it AC, or is it some legacy setting that I have failed to fix?
