Greetings. I cannot find the setting to remove the presentation shading from the Door Legend. I need the legend to be lines only, no shading. Please let me know if this is possible. Thank you, Scott
AC27 v. 4060 w/ MEP, Cadimage, Twinmotion 2023.2.2 using AC from AC6.0, 2021 MacPro M1 chip, Adobe CC. Used AC on both platforms.
The Options Bar at the bottom is not displayed for Schedules so you may display the Quick Options Palette and you will see the Graphic Override Combination currently active.
But the best way is what runxel said: save a View and activate that to generate the Schedule so it looks the way you want.
Loving Archicad since 1995 - Find Archicad Tips at x.com/laszlonagy AMD Ryzen9 5900X CPU, 64 GB RAM 3600 MHz, Nvidia GTX 1060 6GB, 500 GB NVMe SSD 2x28" (2560x1440), Windows 10 PRO ENG, Ac20-Ac28
It's not as intuitive, but the interactive schedules take the settings from the last opened view.
Also you should then save a view of the schedule with your preferred view settings.
Make a GO where all fills are set to transparent, if you haven't already, then assign this GO to the view. Voilá! There you have it like you want.
