Scott Bulmer
Door Legend in Presentation Mode - AC24
Greetings. I cannot find the setting to remove the presentation shading from the Door Legend. I need the legend to be lines only, no shading. Please let me know if this is possible. Thank you, Scott
AC27 v. 4060 w/ MEP, Cadimage, Twinmotion 2023.2.2 using AC from AC6.0, 2021 MacPro M1 chip, Adobe CC. Used AC on both platforms.
1 Solution
Scott,
The Options Bar at the bottom is not displayed for Schedules so you may display the Quick Options Palette and you will see the Graphic Override Combination currently active.
But the best way is what runxel said: save a View and activate that to generate the Schedule so it looks the way you want.
Go to post
3 Replies 3
runxel
It's not as intuitive, but the interactive schedules take the settings from the last opened view.
Also you should then save a view of the schedule with your preferred view settings.
Make a GO where all fills are set to transparent, if you haven't already, then assign this GO to the view. Voilá! There you have it like you want.
«GeometricDescriptionLucas» | Lucas Becker | AC 30 on Mac (Sequoia) | Graphisoft Insider Panelist | Akroter.io – high-end GDL objects | Author of Runxel's Archicad Wiki | Editor at SelfGDL | Developer of the GDL plugin for Sublime Text
Scott Bulmer
Hey Runxel, thanks so much, it worked~! Funky way to achieve the desired setting however, perhaps GS could make it a little more intuitive. Scott
Scott,
