Door Schedule - User Defined Parameters
Why did ArchiCAD not include "user defined parameters" in ArchiCAD 20 door library parts? They need to add this back into the script. It gives users more options when scheduling door lists.
1 REPLY 1
Because ARCHICAD 20 introduced Element Properties, which is a more general solution and made the use of such user defined parameters unnecessary and redundant. Define the Element Properties you need and they can be set to be listed in schedules more easily that those Door parameters.
