Door and Window Builder vs. ArchiGlazing
Laura Yanoviak
Can anyone recommend one over the other?
It appears that ArchiGlazing is a good tool for one doing a lot of custom curtainwall/storefront framing, and Door and Window Builder would satisfy the need for just about any punched opening imaginable. If the curtainwall/storefront objects are not significantly improved with AC10, we will have no choice but to purchase one of these add-ons...
TomWaltz
One major difference is that ArchiGlazing is an add-on and must be purchased and installed on each machine with its own auth codes while D&WB is an object kit that you only need to buy once for the office and place in a common library.
It's not related to the features of either one, but can seriously affect the cost if you have a lot of users.
Tom Waltz
Laura Yanoviak
Yes -- thanks -- that does make a difference -- LJY
Link
Not sure about ArchiGlazing, but D&WB has some killer scheduling capabilities!
Link.
