svpribyl
Door and Window Views/Types in Schedules
I'm "old school"...
I would like to have a door and window schedule without elevation "views" included. This is easy enough to do. Then I would like to a assign a door "type" or window "type" to each door and window, with a separate schedule showing only the Door Types.
I'll stick to doors for the sake of this discussion: A door type would be single door, double door, dutch door, louvered door, etc. Anything that looks different in elevation. Size is not relevant if that's the only parameter that is different. I don't want my door schedule to show a view of a dozen doors if they are all the same "type", such as a dozen views of a single-leaf door. I would have only a few views of types of doors in a separate Door Types schedule, with the "type" referenced from the Door Schedule.
I can't find a field for an ID that would allow this to happen. Does anyone have any suggestions as to how to accomplish this?
Thanks!
Steve Pribyl
MAC OS Sequoia 15.5
ArchiCAD 28
12 Replies 12
Eduardo Rolon
If it is blank then you will need to open a new file using one of the templates, then export the Classification and Import it into your file.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
You can download XML Classification systems directly from here: http://www.graphisoft.com/downloads/archicad/BIM_Data.html, or use the ArchiCAD system in their template.
Richard
AC26 (since AC6.0), Win10
svpribyl
Eduardo, that worked! Thanks for your help!
Steve Pribyl
MAC OS Sequoia 15.5
ArchiCAD 28
