Door and window Schedule Line Thickness problem
I have a problem with line thickness of doors and windows in schedules. On floor plans and cross sections thickness of lines is normal. On schedules lines are thick. Do anyone know how can i solve the problem
I didnt change pens for symbol.
This is how schedules look like
This is how door symbols look on floor plans
You can try two things:
1. Check whether the View>On-Screen View Options>True Line Weight toggle is ON. It probably is and you can turn it off so your lines will be hairline. (But you may want True Line Weights, so you may need option 2.)
2. While in the Schedule Viewpoint, go to the Pens & Colors Dialog and see which Pen Set is highlighted as that is the Pen Set currently active in your Schedule. Switch to another Pen Set.
You could also save a View of your Schedule Viewpoint, which will store the Pen Set used. Then you can generate the Schedule by activating its saved View. That should guarantee it is displayed with the correct Pen Set.
Eduardo Rolon
There was a bug that used to cause this so check that AC is up to date too.
Eduardo Rolón AIA NCARB
AC28 US/INT -> AC08
another Moderator
