Door schedule front view
I! any body know why in the cell of the front view of the door schedule, if I use commercial door the swinging line show up, if I use wood internal door the same swinging line it doesn't.
Thanks to everybody
6 Replies 6
I suppose the Opening Line in 3D parameter is differently set for the two Doors.
Thank you Laszlo, but I check both setting and they are on, on both settings, and still don't show up.
Then the Opening Line Type Inside / Opening Line Type Outside parameters may be set to None.
Thank you Laszlo, but in some computer work in others not.
Laszlo, please can you post a screen shot of the setting that I need to turn on please Thanks
Here it is.
