2006-05-08 06:13 PM
2006-05-08 09:57 PM
Sergio wrote:Sergio,
I'm trying to create a IS door schedule, and would like to use the "Door Panel" parameter (the one that lists "Flush", "Standard 4 Panel", etc), but can't seem to be able to get it into the schedule....
2006-05-08 10:20 PM
Dan wrote:Sorry, I guess I explained it a bit wrong. I tried finding the parameter via the "Additional Parameters...". I ended up bringing ALL the "Additional..." parameters and still couldn't find it.
What Door and/or what Library are you using? You might be able to bring the parameters in under "Addtional Parameters..." in the I.S. Schedule Settings.
2006-05-08 11:06 PM
Sergio wrote:I could be wrong, but I think that's a crytpic parameter anyway. The doors are called "style 1", "style2", and so on. I'm not sure how useful that would be to you.
I'm trying to create a IS door schedule, and would like to use the "Door Panel" parameter (the one that lists "Flush", "Standard 4 Panel", etc), but can't seem to be able to get it into the schedule. I ended up bringing ALL the parameters into the scheduler (including linetypes, materials, etc) just in case, and still no sign of that parameter. Anybody care to point me in the right direction, or at least let me know that it can't be done?
Also, would there be a better way to schedule the types of doors in the project (6-panel, 4-panel, flush, etc)?
2006-05-09 12:51 AM
TomWaltz wrote:That's what they usually come out as when listing them in the schedule (provided I'm using the right parameter, which I doubt). The parameter that I'm talking about is found in the door object itself (D1 SE9), under Parameters -> Door Panel -> Door Panel
It's called gs_door_typAre we still talking about the same parameter? I think the one you mentioned was mostly something from the original 9 library. Also, how would I pull in a "gs_door_typ" parameter in the IS? Or am I missunderstanding something?
2006-05-09 06:10 AM
The parameter that I'm talking about is found in the door object itself (D1 SE9), under Parameters -> Door Panel -> Door Panel(first option), and the options go something like this:
- Flush
- Standard 3 panel
- Standard 4 panel
- Eyebrow 4 panel
- Victorian 6 panel
- ... etc
