Export IFC with local origin (native survey point)
PVBergkrantz
Hello, we have recently started using AC25 and the new native survey point feature, which is working very well for export to DWG, but we are having trouble with the IFC export. No matter the settings in the IFC translator under Geometry Conversion it seems to use the survey points location. We would like to be able to chose wether to use the survey point or local origin, same as we can with DWG.
Is there perhaphs a new settings hidden somewhere, or should I approach this in another way?
| AC 25 Int | Win10 | i7-7800X | 32 GB | GeForce RTX 2060 6GB |
2 ACCEPTED SOLUTIONS
Zsolt Oncsak
Dear All,
@rohanbailey  said it right, the referred translator option only changes the IfcSite location parameters and not the actual position of the model. Currently, the Native Survey Point in AC25 works like it used to; the SP will be used as the global origin of the IFC model. So for now, you need to place the Survey Point back to Project Origin location if you want to export a model with PO as Global Origin.
Good news though: With the Update 2 (build > 4000) coming for AC25 this Automn, this issue will be addressed. The option within the Geometry Conversion in the IFC Translator Settings will be enhanced, so we will be able to choose if we want to ignore the SP for the export.
Until then, we thank you for your patience and understanding, and I hope you'll be happy with the new solution.
Best regards,
Zsolt Oncsak
GRAPHISOFT | H-1031 Budapest, Záhony utca 7. | Graphisoft Park ‘G’ | +3614373000 | zsoncsak@graphisoft.com
PVBergkrantz
In the latest version of Archicad 25 (4013) there are more options in the IFC translator settings, which now allows this to be adjusted and it seems to work well, so I consider this solved.
13 REPLIES 13
hybrid
Hi. You can show the IFC setting of the translator?
AMD R7 2700 3.8@GHz | 32 Gb RAM | SSD | GTX 1050Ti
Marius Mikeliunas
Same in our company. We work with subcontractors, and they prefer to use local origin. Same file, exported with AC24 is OK, but exported with AC25 gets rotated/relocated.
W11, AC26
We also have this annoying ISSUE/BUG. It does not matter what we select "Project Origin" or "Survey Point" in IFC geometry conversion.  IFC still gets exported according built in Archicad 25 survey point rotation. Archicad 25 build version 3011 - INT.
Archicad development team should include such things into TEST'ing cases when releasing new Archicad versions. TESTING - TESTING - TESTING.
GRAPHISOFT BIM Manager Training Week attendee
ArchiCAD v9 - v27 INT / NOR (5030)
cpu i5-12600K @ 5.0Ghz, ram 32GB, gpu 1060 GTX
ssd NVMe, Windows 11
ArchiCAD Discord channel: https://discord.gg/QdWxSJ33
hybrid
Hi. What software are you using?
We are using Archicad 25 INT build 3011 for exporting IFC.
Contractors are using. AutoCAD, Revit, BIMsync for IFC colaboration, Pamir and other.
PVBergkrantz
Yep, exactly like Algimantas Kuprenas described the translator. We are using 25 SWE build 3011. The new system works fine for DWG, but not IFC.
The IFC will always use the Survey Point. If you want to export to Project Origin leave your Survey Point at the project origin (where it starts when the project opens).
The selection in the translator concerns the global location of the IFCsite (not the origin of the IFC). Whether the coordinates documented in the IFC data is in relation to the local coordinate system or in relation to the determined site set out point.
ARCHICADUser and Technology Manager
Various macOS versions and hardware
See reply to Algimantas Kuprenas
Hi rohanbailey,
Thanks for help, but to be frankly I don't understand how it works in AC25 😞
We work on project file (TEAMWORK) together with architects and others, and they input project information rotation information. So every time I publish *.ifc I need to change that value to 90 degrees > Publish IFC > change project rotation back to architects value. I just want to publish *.ifc files that they are not rotated, but show like they are in Archicad workspace.
