Export from ArchiCAD PLN to AutoCAD
What's the best way to Export from ArchiCAD PLN to AutoCAD with layers and every things ?
thank you
6 Replies 6
'Save As' and change the file type to DWG or DXF.
You will then want to have a look at the translator options as there are quite a few settings affecting how it saves.
You might want to look up translators in the Help Centre.
Greg D
How does one export the entire plan file as a dwg file? It appears that if you 'Save As...' in the plan window, all you get is that layer set in that view.
Greg Danskin - Architect
http://www.danskinarchitecture.com
AC 19/20/21
iMac Retina 5K, 4 GHz Intel Core i7, 32 GB 1867 MHz DDR3, AMD Radeon R9 M395X 4096 MB
OS 10.13.4 High Sierra
In the DXF-DWG Translation Setup Dialog, in the Settings panel, in the Attributes\Layers\Methods page, is the "Save Elements On" field set to "All Layers"?
Erika Epstein
You can also set up a publisher set for DWG with views and/or layouts to streamline the process.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
David Collins
I'm confused about Model Space and Paper Space in AutoCAD and all those years of contemptuously ignoring AutoCAD haven't helped me here. I need to convert the layout drawings from a 3d ArchiCAD model to simple editable 2d DWGs. I want to avoid including any part of the 3d model.
First of all, is Paper Space more or less like our Used-to-be-Plotmaker layout drawings? Or is Paper Space a fully editable flatland 2d environment?
Do ArchiCAD layout drawings automatically go into AutoCAD Paper Space layouts? Is there a setting that will convert ArchiCAD Layout Drawings into Plain Vanilla Flatland 2d drawings. Or does that happen more or less by default when you convert to DWG? Is there a difference between using Publisher to convert to DWG and simply saving as DWG?
I get that the translator settings gives you complete control over how the ArchiCAD drawing is converted, but you need to be pretty familiar with AutoCAD to get anywhere with it. I suppose I could learn AutoCAD.... Nah.
Thanks
David Collins
Win11 64bit Intel i9 3.40 Ghz, 64 Gb RAM, GeForce RTX 5080
AC 29.0 (3100 INT FULL)
Yes, the AutoCAD Paper Space is the equivalent of the ARCHICAD Layout. It is a digital sheet of paper onto which you place your Views for printing/plotting.
This is controlled by the Save Layout Into field. I think what you want is achieved by setting this field to the "Model Space" option, in which case the Layout and its contents will be converted to a simple 2D DWG drawing.
Thanks
I think you should read this page of the Help Center:
http://helpcenter.graphisoft.com/guides/archicad-19-int-reference-guide/user-interface-reference-2/d...
Especially the description of the Save Layout Into, Place Drawings into and Saving Floor Plan fields.
What I would recommend is that you save multiple copies of the Layout, each time with a different Save Layout Into settings. Then open each of these in AutoCAD or some other DWG application and compare the results. Then you will have a good grasp of the differences between the various options.
