‎2021-09-02 01:20 AM
We hotlink pln files (unit plans) into Teamwork building plans.
Is there a way to export to DWGs with linked xrefs (for consulants). They want to be able to retain the link between the building file and the individual unit plans.
‎2021-09-06 03:09 PM
I am not aware of any option the DWG/DXF Translator Dialog that could achieve that.
You can make a wish for this feature, we can vote on it and if it gets enough support, we can submit it to GRAPHISOFT for consideration.
If you do make a wish, please post its link in this thread.
‎2021-09-07 04:40 AM
Thanks Laszlo,
This was just a request from a consultant. I would rather add some other items to a wish list. For example, a mesh / slab that keeps a constant thickness with top elevations are modified. Used for suspended slabs. Parkade slabs. We use solid element operations but this is tedious.
‎2021-09-07 11:50 AM - edited ‎2021-09-07 11:50 AM
Yes, the Mesh with a constant thickness has been a wish by many for a long time.
So much so, that a few users actually created a Library Part to provide this functionality. Here is the AC24 version:
And someone back-saved it into AC22, so AC22 and AC23 users can also use it:
