2007-07-12 01:22 PM
2007-07-12 02:34 PM
2007-07-12 05:42 PM
Eug wrote:AFAIK AutoCAD does not have IFC support, at least not in v2007 (might be different in 2008) and certainly not full (2X2 or 2X3) support even if it might happen to read the file. Which is wierd, of course since Autodesk were one of the founding members of the IFC initiative, and now seem to be against it.
I found that the IFC model that I have drew in ArchiCAD is not compatible in AutoCAD, where no modification can be done in the model. Is there any way for me to cross use the IFC component in both ArchiCAD and AutoCAD?
2007-07-12 06:06 PM
2007-07-12 09:55 PM
Bricklyne wrote:Both AutoCAD Architecture and Revit support IFC 2x3 -- so Autodesk can hardly be said to be against IFCs! It would be great if all the AEC developers out there got IFC to work seamlessly, but there's only so much we can hope for
2007-07-12 10:45 PM
metanoia wrote:Bricklyne wrote:Both AutoCAD Architecture and Revit support IFC 2x3 -- so Autodesk can hardly be said to be against IFCs! It would be great if all the AEC developers out there got IFC to work seamlessly, but there's only so much we can hope for
AFAIK AutoCAD does not have IFC support, at least not in v2007 (might be different in 2008) and certainly not full (2X2 or 2X3) support even if it might happen to read the file. Which is wierd, of course since Autodesk were one of the founding members of the IFC initiative, and now seem to be against it.😉
As for vanilla AutoCAD and IFC -- it doesn't support it OOTB because AEC BIMmers on the AutoCAD platform ought to be using AutoCAD Architecture anyway. Or thinking about switching to some program that doesn't have display representations😛
