Exporting Curtain wall layers
Hello!
Im trying to save my curtain wall components in different layers, specifically a want the glass panels in a layer and the boundaries and the mullions in another layer.
The reason for this is that I want to export the 3D model in 3dsMax where it would be easier for me to add materials.
I already tried converting the curtain walls into morphs and manually moving the panels in another layer, but im wondering if there's another less time consuming way to do this.
1 REPLY 1
Eduardo Rolon
The usual trick is assigning different materials per element type and then export using "…by material" option
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
