Fake Schedule
I am trying to edit the numbers in a schedule created in Archicad. Is there a way to manually enter the numbers and names? The exterior walls to my building are made of glass. THe glass wall, in reality, will be made up of glass panels (windows). I have drawn the panels in 2d rather than model them in all over the building. So basically my question is, how do i take my existing window schedule and manually change the numbers in it?
Thanks!
Eduardo Rolon
The ID column should not be using the ID parameter of the object but it should be a "Custom Text" one.
On another note I sometimes create dummy objects instead of drawing in 2D. In this case you could have created rectangular morphs placed in a wall with an empty window to create the hole. This Morphs could then be listed with their IDs without problems.
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
Can you show a picture of what it is you want to model and put in the schedule? If so, it would be easier for us to recommend a method for scheduling that will work for you.
Save the schedule as an XLS (Excel) file and then you can do whatever you want with it.
