License Delivery maintenance is expected to occur on Saturday, October 19, between 4 and 6 PM CEST. This may cause a short 60-minute outage in which license-related tasks: license key upload, download, update, SSA validation, access to the license pool may not function properly. We apologize for any inconvenience.
Genratin mesh from survey .txt file
Traian
Hi guys!
I have a problem. I'm trying to generate a mesh automatically from the surveyor's data by using the .txt file, but I keep getting this error message:
 The .txt file looked like this:
I don't know if it's relevant, but the coordinate system used is Stereo 70 (old I know, but mandatory where I'm from).
The reason I want to do it like this, even though it's only 6 points with no Z data, is that I want to make sure that when I will save the site plan as a dxf, the government officials who analyze the project, would be able to open the file and correctly identify the lot (with stereo 70 coordinates)
P.S. I also added a zip with the data I got from the national agency of cadastre. (perhaps there is a better way than what I'm thinking of)
Thank you for your time 🙂
Operating system used: Windows 10
vlahtinen
Have you tried to remove the first column containing 1, 2, 3...? I think Archicad accepts only three columns (x, y and z).
vlahtinen
Also try to remove the leading zeros from the z value, so that every z value is 0.000
Setup info provided by author
