This parameter can be added to an Interactive Schedule via the Scheme Settings > Available Parameters: Add Object Parameters option from the pop up list in the lower left of the dialog box. You will then need to navigate to the library part you are using and select the specific parameter to add it to the Interactive Schedule. In the Help files see: User Interface Reference > Dialog Boxes > Scheme Settings Dialog Box (Interactive Schedule): Add Object Parameters.
Thanks for your help, I've found it.
I've noticed it that the glass surface isn't calculated to the specific window-/door model. All are set on 0,00 m2, which is a pity.
Lets hope Graphisoft will BIM this feature in AC17.
Could you post screenshots that show the exact object parameter you are trying to show in the schedule and the result in the schedule.
This is too little information. The more information we provide to GRAPHISOFT the better chance there is that they can fix the issue.
Loving Archicad since 1995 - Find Archicad Tips at x.com/laszlonagy AMD Ryzen9 5900X CPU, 64 GB RAM 3600 MHz, Nvidia GTX 1060 6GB, 500 GB NVMe SSD 2x28" (2560x1440), Windows 10 PRO ENG, Ac20-Ac28
It's the real number parameter for Basic window called "gs_list_glassarea". It always displays 0m2 in schedules (I guess because it's not a length parameter). I think there is no length parameter that actually calculates only the glazing of a window.
I think I have a solution. You can make a surface schedule and list the surface parameter 'exposed surface'. As criteria you can for instance use window+surface material.
You have to divide the results by 2 as it counts the glass on both sides of the door/window. I find this method limited to single planar surfaces... if say you have a convex or concave surface...!
