nori0003 wrote:
My question is if there is a possibility of making AC calculate the area of walls on the reference line? That will solve the problem.
Yes you just need to choose the correct parameter in the schedule field list.
Gross area does not take into account openings or Solid Element Operations.
Net area and Conditional area do allow for opening - I can't remember the difference between them - maybe one doesn't allow for SEO but the other does.
This changes a bit in 17 as when you use the Priority Based Connections.
The end surface area of a wall will not be included in the surface area of an adjoining wall if it is trimmed by a PBC.
I am not happy with wall areas in 17.
