ICF Walls
Red
We have started using Nudura walls basically in every home now. http://nudura.com/EN/NuduraHome.aspx
The question I have is... Once I create the composite for the foundation wall with foam being on both sides... How do I only get the volume of the concrete without the foam in a schedule list? I hope it's something easy I'm missing.
Thanks,
Red
i7 8700k
ROG Strix Z390-E MoBo
64gb RAM
EVGA GeForce GTX 2080
_______________________
http://www.facebook.com/flatcreekdesignstn
http://www.sraarchitects.biz
AC6 to Current
4 REPLIES 4
It is possible to list Components with the Interactive Schedule.
I think that will do it for you.
Components of both Composite and Complex Structures can be scheduled.
That's also easy if you use ArchiQuant, from Cigraph.
Red
I finally got to go back and work on this today... Once I set my core and finish everything worked out great!
Thanks for the info!
Thanks,
Red
i7 8700k
64gb RAM
AC6 to Current
Steve Jepson
Are you still using Nudura? I am looking for some Foxblock, LOGIX, or QUADLOCK .gsm parts that are better than what I find on Google Warehouse.
Or at least some kind of 3D file that is easy to convert to a .gsm.
I made these for a Foxblock project. It takes too much effort to make them right. I may have to just model them from scratch in ArchiCAD.
There must be a set of .gsm ICF object out there somewhere.
