2024-12-02
		05:02 PM
		2024-12-04
		07:11 PM
When you import an IDS file, every property/property set as specified in the IDS, will be included to get imported. However, this way, your Archicad model gets a bunch of Pset_WallCommon and Pset_DoorCommon etc... with no distinction based on classification. This way, a carefully planned model can be filled with "noise".
Now EVERY object gets the Pset_WallCommon and other properties as custom Archicad properties. This means you have to painstakingly redo the classification mappings. Is this the intended workflow?
Solved! Go to Solution.
2024-12-12 08:27 AM
Hi @stefan ,
This is somewhat intended, yes. As the first iteration of IDS support we wanted to give users the ability to work with IDS files, even if that means that some post-import configuration has to be done, it is still faster than manually adding the data from an excel sheet. But your point is valid, so we are already working on making the imported properties available for only the classifications specified in the IDS specification applicability and not set them to "All" by default.
2024-12-12 08:27 AM
Hi @stefan ,
2025-05-07 05:54 PM - edited 2025-05-07 05:58 PM
@Zoltan Vale How to ask Graphisoft to add the new entry for IDS import implementation on buildingSMART International website? https://technical.buildingsmart.org/ids-software-implementations/
2025-05-07 05:57 PM
@Zoltan Vale What about the properties you already have defined within through the IFC Translator Property Mapping setting (or IFC Project Manager / Object Setting bottom dialogue)?
2025-05-08 09:27 AM - edited 2025-05-08 09:28 AM
Hi @davdelven ,
I have added Graphisoft Archicad to the list of implementers on the buildingSmart site. They only provide options for IDS authoring or IDS based checking. So in the situation where importing is not explicitly separated I have added IDS authoring to the list and also updated some other missing information there.
In regards to the properties, when we import from IDS:
Hope this helps to clarify a bit,
Have a great day.
2025-05-08 09:54 AM
Thank you for the clarification, @Zoltan Vale
So if I understand correctly, the optimal workflow would be to select one of my existing IFC mapping presets when importing an IDS file, rather than creating a new preset. This way Archicad will preserve all my current IFC property configurations while only adding the new properties from the IDS requirements that don't already exist in my setup.
This incremental approach makes sense as it allows me to maintain my carefully configured mappings while still benefiting from the standardized properties in the IDS specification.
Have you considered adding an option in future versions to visualize which properties would be added versus preserved before completing the import? This could help users make more informed decisions about which existing preset to use.
2025-05-08 10:07 AM
@davdelven That seems to be a good suggestion. I was already hoping that the IFC mappings could be recovered, but I didn't fully grasp the most optimal workflow, hence my post.
