‎2009-05-13 09:40 AM
‎2009-05-13 06:03 PM
NandoMogollon wrote:I suspect it is a bit of both -- IFC has a way to go, and the way Profiles are handled I would think is an AC issue. We've found that many time the Profiles are displayed in Solibri backwards. We use a lot of Complex Profiles, so this is a real problem. Sorry, haven't found any solution yet.
Do you know if ther is a generic problem with IFC? or is it just a handicap from ArchiCAD in translating the SEOs and Profiles?
‎2009-05-13 07:07 PM
Laura wrote:I've had the same problem with Custom Profiles. Fiddling with wall direction and/or mirroring the Custom Profile usually gets it to where I want it. If they are really bad, I will just leave of the layer before saving if the consultant doesn't need it. Consultants always get a set of pdfs of the architectural and I can point out what was left out of the IFC.
‎2009-05-15 12:25 PM
‎2009-05-20 10:05 AM
Laura wrote:Dear Laura,NandoMogollon wrote:I suspect it is a bit of both -- IFC has a way to go, and the way Profiles are handled I would think is an AC issue. We've found that many time the Profiles are displayed in Solibri backwards. We use a lot of Complex Profiles, so this is a real problem. Sorry, haven't found any solution yet.
‎2009-08-03 04:43 PM
‎2009-09-01 12:42 AM
‎2009-09-08 01:12 AM
didrik wrote:Same results with Build 63138.
ArchiCAD 12, IFC beta 63137, and SMC 5.0.0.180 still have a problem maintaining wall joins where two walls were created with a custom profile. [...]
‎2009-10-19 04:40 PM
‎2009-10-19 06:00 PM
didrik wrote:Will check soon. Meanwhile, at least some SEOs in AC13 appear not to come over to SMC 5.1 via IFC beta 64130.didrik wrote:Same results with Build 63138.
