2022-11-08 11:07 AM - last edited Tuesday by Laszlo Nagy
Hey guys I need little help with formatting coordinations.
I'm doing terrain model from DWG drawings
1. I got 3D Lines / curve - > I opened in Rhino and exported from lines to points and save like . txt = XYZ
2. I opened in "notepad" and remove all symbols what I don't need it
3. Then I opened in Excel and export to the 3 columns
After all my work with it ... I stile cannot export it to Archicad 😕
I got Error note
What's wrong I'm doing ? It's becoming quite complicated but I really would like to learn it how to do it.
*No Elements were created. The source file is corrupted, is not in the right format or doesn't contain valid coordinates.
Solved! Go to Solution.
2022-11-08 11:35 AM
I work with tabulation for separator and no comma (point).
After a second look, your numbers seems really big. I always work with meters. Perhaps a problem in this direction?
2022-11-08 11:24 AM
what kind of separator (tabulation, semicolon, comma... ) did you use?
when you open the xyz file with textedit?
2022-11-08 11:30 AM
I replace all separation and put all numbers in to the columns in excel. I think that i tested all of them 🙂 which one is correct ?
2022-11-08 11:35 AM
2022-11-08 11:40 AM
Thanks this is it ... I exported in meter but My export was in millimeters.
I fixed it just change meter to millimeters
