Import Terrain XYZ - Error is not in the right format
Hey guys I need little help with formatting coordinations.
I'm doing terrain model from DWG drawings
1. I got 3D Lines / curve - > I opened in Rhino and exported from lines to points and save like . txt = XYZ
2. I opened in "notepad" and remove all symbols what I don't need it
3. Then I opened in Excel and export to the 3 columns
After all my work with it ... I stile cannot export it to Archicad 😕
I got Error note
What's wrong I'm doing ? It's becoming quite complicated but I really would like to learn it how to do it.
*No Elements were created. The source file is corrupted, is not in the right format or doesn't contain valid coordinates.
AC 7 - 27 SWE
iMac (Retina 5K, 27-inch, 2020),
3,6 GHz 10-Core intel Core i9, 64 GB 2667 MHz DDR4, AMD Radeon Pro 5700 XT 16 GB
Mathias Jonathan
I work with tabulation for separator and no comma (point).
After a second look, your numbers seems really big. I always work with meters. Perhaps a problem in this direction?
4 REPLIES 4
Mathias Jonathan
what kind of separator (tabulation, semicolon, comma... ) did you use?
when you open the xyz file with textedit?
I replace all separation and put all numbers in to the columns in excel. I think that i tested all of them 🙂 which one is correct ?
AC 7 - 27 SWE
Mathias Jonathan
Thanks this is it ... I exported in meter but My export was in millimeters.
I fixed it just change meter to millimeters
Skärmavbild 2022-11-08 kl. 11.38.37.jpgSkärmavbild 2022-11-08 kl. 11.38.19.jpg
AC 7 - 27 SWE
