2008-02-11 10:54 AM
2008-02-11 02:39 PM
another Moderator
2008-02-12 06:38 AM
2008-02-12 04:22 PM
2008-02-27 11:15 PM
2008-02-28 03:13 PM
2008-03-16 11:14 AM
2008-03-16 07:01 PM
2008-03-18 04:36 AM
2008-03-18 01:04 PM
David wrote:FYI, I just opened the file using SketchUp and exported the 3D as 2007 DWG and it was opened by AC without problems. There is a lot of extra "unnecessary" detail in the model, like bolts and plates. Apparently there is something extra in the 3D file incompatible with AC's translator that does not affect SketchUp. Once SU "cleans" it then AC's translator works. According to SU's translator there is an ignored Autocad solid but the model is complete though it is not "standing up".
Symm:
This is just to confirm your experience. I tried one of the 3D files from Sub-Zero and also did not get any 3D model. The 3D Script has some commands for ensuring a minimum size and a transformation, but then ends. A 3D Script from another file starts the same way, then has a bunch of Lin_ commands to create the 3D model, so the Sub-Zero is definitely not coming through. Sorry I have nothing to recommend.
another Moderator
