2010-01-09 02:12 PM
2010-01-09 02:40 PM
2010-01-09 08:06 PM
2010-01-09 08:08 PM
rob2218 wrote:It depends on your needs.
what's the best to import an OEM file like Excel or a word doc into archicad???
2010-01-09 08:16 PM
rob2218 wrote:XCL got me confused. Excel files are XLS
wow....Really? such a sophisticated program and you can only import PDF's or JPGS but no XCL files??? wow....bummer.
would've been nice to work "ON" the actual XCL file right inside the archicad PLN file. so I guess each time you'd have to open the XCL file, edit it, then print to PDF and simply overwrite (rename with the same name) the PDF that is already taking the place holder in the archicad file?
