2012-04-21 04:52 PM
2012-04-26 05:28 AM
2012-04-26 09:01 AM
2012-04-26 04:54 PM
2012-04-26 10:07 PM
Enrico wrote:You can save the beam/column assembly as a window subtype and apply it to a copy of the window unit in the same location. This would need to be enlarged to the default size of the frame part.
I know I coulg go "around" the problem by creating the window frame using columns/beams with custom profiles, but then AC would not recognize them as a window.
2012-05-09 01:59 PM
2012-05-10 08:28 AM
KeesW wrote:use the Fill tool on the DWG imported drawing, then copy the fills and paste them in the Profile Editor Window
Wow - how relevant Archicad-talk often is!
I've traced the DXF image with a polyline, copied this into complex profiles and thus created a frame for use in my drawings. Tracing is not completely accurate and it would be nice if we could somehow use the DXF/DWG drawings on the screen and convert them into polylines. Am I dreaming? Is there an easier way?
2012-05-10 08:37 AM
2012-05-10 09:43 AM
KeesW wrote:Would the line consolidation tool help to simplify the DWG/DXF if there are many line segments?
I am trying to convert DXF/DWG window profiles from my AWS catalogue into complex profiles for use in a current, and future, projects. I've traced the DXF image with a polyline, copied this into complex profiles and thus created a frame for use in my drawings. Tracing is not completely accurate and it would be nice if we could somehow use the DXF/DWG drawings on the screen and convert them into polylines. Am I dreaming? Is there an easier way?
KeesW wrote:You need fills anyway for your complex profiles so why not use those in the first place.
Thanks for your suggestion. I thought of this but have found, in the past, that using the fill tool was only marginally quicker than tracing with a polyline. However I'll use that method next time to see if I am any nore efficient with it.
2012-05-11 07:06 AM
