‎2007-02-12 05:20 PM
‎2007-02-12 05:26 PM
‎2007-02-12 09:58 PM
‎2007-02-12 10:55 PM
henrypootel wrote:
Hi Chazz.
I have attached the section from the help file which deals with the Door and Window Scheduling...
‎2007-02-12 11:21 PM
‎2007-02-13 03:01 PM
henrypootel wrote:Thanks Henry.
I have attached the section from the help file which deals with the Door and Window Scheduling. It is a straight walkthrough of the process, so you shouldn't have nay trouble with it.
‎2007-02-13 03:14 PM
Dan wrote:Dan, I'm a big fan of the Theometric/Cadimage stuff. I currently make heavy use of D&WB, StairBuilder, Cabinetbuilder and 3D Profiler (better in many ways then the current AC Profiler). They are sophisticated tools and while there is an associated learning curve, there is real power behind their approach. While there are occasional gotchas as evidenced here, I still recommend them overall. Their support reputation seems to take a beating on this forum but I have not made enough use of it over the years to comment one way or the other.
I've always been curious about Door & Window Builder and have recently considered purchasing it....but not if you can't easily use Graphisoft's IS.
‎2007-02-17 03:52 PM
‎2007-02-17 07:39 PM
‎2007-02-18 05:08 PM
