Tom Krowka
Label with notes to schedule
Am looking for a label that will includes notes. These notes can then be pulled out of the labels with a schedule to make a list of notes. Am using it notes on the plans and elevations. Am doing it the old fashioned way with a text label and number on the plan/elevation, then simply using text to type up the list that corresponds to the labels.
Would like to link them. Can't seem to figure out a way to do that.
Thanks.
Tom Krowka Architect
Windows 11, AC Version 26
[email protected]
www.walshkrowka.com
3 Replies 3
Eduardo Rolon
Something like this?
http://archicad-talk.graphisoft.com/viewtopic.php?t=26004&postdays=0&postorder=asc&&start=20
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
Tom Krowka
Close, but not exactly. Would like the key note indicator (not really a label in the technical AC sense) to be able to accept 250 characters, like a text box but only show the key indicator (like #7, or B-2) The text within that note indicator could then be listed in a text box, in a similar fashion to a schedule. Don't want to buy a cadimage add-on tool.
[email protected]
www.walshkrowka.com
Eduardo Rolon
Then look for James Murray's Label object to which you can add an IFC Parameter for (Keynote Number and Keynote Description) then when you place de object you can list the KN or the ID and in the schedule you list the object and the description. This will be easier in AC20 with the new Properties. You can also so this with the Multileader Label in AC19's library.
AC29 US/INT -> AC08
