Labels Schedule
NandoMogollon
Hi all
I wanted to create a Schedule for Labels, so we can have a set of Favorites labels, and keep those up to date without having to make the changes manually on each and every label.
Am i clear? i just want a schedule that lists the favorite labels, and change the content from there if it's necessary...
I think it should be possible since the schedules are a "small window" to the data base...
Any ideas or work-arounds to achieve the same thing??
Regards
Nando
Nando Mogollon
Director @ BuilDigital
nando@buildigital.com.au
Using, Archicad Latest AU and INT. Revit Latest (have to keep comparing notes)
More and more... IFC.js, IFCOpenShell
All things Solibri and BIMCollab
48 REPLIES 48
alemanda
Yes!
I'm in front of PC now and you caught me!
My method is based on IFC properties and data mapping.
So, 1st thing to do is to define the IFC properties like this (see picture below).
As you can see I defined my IFC properties in order to have Masterformat division and code, spec text (where you will type your specification text), BOQ ref (it is used in order to group your item in BOQ oriented way - for exampl CAWS)
Once you fill these IFC properties for each element of your Archicad BIM model, you can use the tag&categories label (chosing the spec code property) in order to have keynote in your drawings.
AC27 latest hotfix
Win 10 Pro 64bit
Double XEON 14 CORES (tot 28 physical cores)
32GB RAM - SSD 256GB - Nvidia Quadro K620
Display DELL 25'' 2560x1440
www.almadw.it
alemanda
Here's what you can get in a 3D drawing for example.
Of course you can schedule these IFC properties.
AC27 latest hotfix
Win 10 Pro 64bit
www.almadw.it
alemanda
Here's an example of how to get a list of all the specifications with a schedule
AC27 latest hotfix
Win 10 Pro 64bit
www.almadw.it
Karl Griffith
I have been using a similar system, I believe, utilizing ArchiCAD Properties. Where I get into difficulty is with elements such as complex profiles and composites, where there are multiple materials for a single element. The system we use identifies each material with a keynote, so for such elements one has to create multiple keynote properties for the element. It can work, but it makes labeling and scheduling a bit more complex.
A screen shot of the properties for a wall set up like this is attached.
But keynotes independent of construction elements would still be helpful for notes not directly related to a material or element.
ArchiCAD 22
Win 10
alemanda
Regarding the BOQ ... considering that the elements can be computed by linear meter, square meter, cubic meter, horizontal projected area, true area (horizontal or slanted), vertical area, lumpsum, by piece ...
I defined 2 IFC propertyes: "quantity" and "unit" and the data mapping rules in order to have
- elements classified as "beams" gives quantities by linear meter
- elements classified as "morph" gives quantities as cubic meter
... and so on ...
So, for example, if I want to have the quantity in linear meter of skirtings I will model them as walls, beams, columns, or whatever ... then I will classify them as beams in order to get the quantity by linear meter.
Data mapping rule will do the "translation" ... see below.
At the end I will set a schedule showing IFC properties showing masterformat or BOQ ref value and quantity and unit ...
That's it
AC27 latest hotfix
Win 10 Pro 64bit
www.almadw.it
alemanda
My system is based on the assumption
one element = one keynote
In case of an element consisting of more elements I will consider as assembly in order to have one keynote only.
This is the limitation of my system.
Pro of my system is that I have one-click coordinated BOQ+specifications+keynote
CONS (one of them) is that I have to model every element which I need the quantity of
AC27 latest hotfix
Win 10 Pro 64bit
www.almadw.it
alemanda
BOQ appears as it follows.
Of course the system is not perfect and there are some limitations in Archicad that don't allow me to get what I prefer under a graphical point of view ...
AC27 latest hotfix
Win 10 Pro 64bit
www.almadw.it
Thanks. I think I can do that!
alemanda
I would like to add that using properties is much, much faster than IFC properties. This with regard to specifications. Schedule of specs is created almost in real time. Using IFC properties for this purpose is, on the other hand, much slower ...
AC27 latest hotfix
Win 10 Pro 64bit
www.almadw.it
