2008-08-21 10:09 PM
2008-08-22 04:23 PM
2008-08-22 08:49 PM
2008-08-22 10:18 PM
2008-11-06 11:08 PM
Rick wrote:I'm trying to get a handle on this thing as well. I've got mine set up like this but I'm coming out with 7 studs in a 2' wall. Any ideas what I might have wrong? My calculations option is set to feet, not inches. Does the script have to be changed?
Change unit to pieces, that might do it. There should be a pre-defined component in your data base all set up. See screen shot. However, I might have made this, I don't remember. I use 1 stud per foot, as I was taught in the early 70's, for 16" oc take offs. That pretty much takes care of the corners and jack studs. If you are literally wanting one stud per 16", then that is probably a different story. I try to keep it simple and not think too much, that hurts.
2008-11-07 05:17 PM
2008-11-07 05:58 PM
2008-11-07 06:06 PM
2008-11-07 06:22 PM
2008-11-07 06:35 PM
