2009-09-30 11:50 PM
2009-10-01 09:09 AM
2009-10-01 04:44 PM
2009-10-03 05:55 PM
2009-10-04 12:51 AM
Greg wrote:It is the same in 13 as it was in 12. The MEP library is a 'sister' ('brother'?) library to the ArchiCAD library - in the application folder. You need to load 'MEP Library 13'. If you load the installed MEP Template, the library will be loaded as part of that template.
I had the same issues as Ted. Followed his lead. MEP is now installed. However, when I proceed to use MEP I get a message that I have "no library objects". I go to Library Manager. There is no library available to apply. HELP? What did I miss?
2010-06-28 06:10 PM
2010-06-29 01:34 PM
2010-06-29 02:33 PM
