gdford
Manage IFC Properties
OK - I select a modeled or library object and open the elements selection settings.
If you scroll down to the very bottom of the selection settings, there is a large button that says "Manage IFC Properties"
I do not see the place where that button takes me available as a hotkey or a menu item.
Am I missing something?
Surly I can just select an object and be able to go directly to "Manage IFC Properties"
Thanks
Gary Ford
Self Employed - Modeling, Estimating, Construction
Archicad 12-26
AMD Ryzen 9 5900X 12-Core Processor
3701 Mhz, 12 Core(s), 24 Logical Processor(s)
(RAM) 128 GB
NVIDIA RTX A2000
4 Replies 4
hevi
Ace
The place it takes you to is identical to the fold out pane of the IFC Project Manager (Ctrl + Alt + I).
But why doesn't opening the manager with an active model selection make the selection show in the list? Now we have one extra click command (show model selection in list) to get where we want.
As expressed here I think there should be an effort to consolidate management of elements. Having it spread across element selection settings, edit selection set, IFC manager and schedules is a mess.
gdford
Ctl + Alt + I does not take you to the same place as the "Manage IFC Property" button found at the bottom of an objects selections settings.
Gary Ford
Archicad 12-26
(RAM) 128 GB
NVIDIA RTX A2000
hevi
Ace
Isn't the right pane of the IFC Project Manager the same as Manage IFC Properties dialog?
gdford
OK - I see what you are saying - thanks
Gary Ford
Archicad 12-26
(RAM) 128 GB
NVIDIA RTX A2000
