Work with external software and open exchange formats (IFC, BCF, DXF/DWG)
Multi-Storey Zone GFA Calculation Schedule
How can I calculate the total area of units in a multi-storey development?
I would like to show the following criteria in a schedule:
Unit Type / Total Area / Ground Floor Area / 1st Floor Area
I had the same problem with total unit areas, adding the unit zone area and the balcony zone area for an apartment area schedule.
Any help would be appreciated.
Cheers
1 REPLY 1
poco2013
Mentor
You have four different criteria
Just create a new property group and then add the four different criteria (locations/usage) as properties, Then use those properties as summary fields in your schedule(s).
If you want to sub-divide your criteria as in "all rooms on a floor" - etc. I believe you would have to make four separate schedules - one for each criteria (group)
Then set the proper locations/usage in the applicable properties for each zone.
Also note that you can create overlapping zones as a alternate?
See property manager in Archicad 20 under Options.
Gerry
Windows 11 - Visual Studio 2022; ArchiCAD 27
