‎2005-02-21 10:02 PM
‎2005-02-23 06:57 PM
‎2005-02-25 10:39 PM
‎2005-07-07 06:19 PM
‎2005-07-07 09:52 PM
The problem is i cannot get the IS to display the Room Number and Door ID. I know this has been a previus topic before. And there seems to be a workaround.I'm not sure I see the problem.
‎2005-07-08 01:16 AM
But the workaround only works if all doors are referenced to the swing side. If they are you, can list the zone number as posted and sort by it. But if you have, for example, a room off of a corridor. And the door swings into the corridor but you want to door to have the room number instead of the corridor number, you must flip the marker into the non-swing side. When that happens and you use the workaround above the door is labeled wrong because it pulls the zone id from the swing side.
‎2005-07-12 10:15 PM
‎2005-07-13 07:02 PM
‎2005-07-18 05:46 PM
‎2005-07-28 06:09 PM
