2009-02-11 07:11 AM
Architects routinely use modeling software, but the latest version of Digital Project would enable them to try extreme designs for skyscrapers. While acknowledging that the Gehry software is impressive, Carl Galioto of Skidmore, Owings & Merrill, a firm that has designed many skyscrapers, says that it is hard to learn and three or four times as expensive as a conventional modeling program. Revit Architecture, the industry standard from Autodesk, is listed at $5,495 on Autodesk’s Web site.
2009-02-12 03:42 PM
2009-02-12 03:53 PM
2009-02-12 04:00 PM
2009-02-12 04:47 PM
Chazz wrote:Well you can always interprete it the other way: Considering Autodesk's market presence and full force behind Revit, I think Archicad holds up very well. The "industry standard" still hasn't overrun AC.
It's pretty clear: this raft is sinking.
2009-02-12 05:16 PM
Chazz wrote:Huh? That was just a graph for search trends!
Google Trends provides insights into broad search patterns. Please keep in mind that several approximations are used when computing these results.ADesk has huge resources and will naturally leverage them as best they can to create a buzz for all their software. A typical issue of AEC Bytes (just an example) will have 10 articles on Revit & 20 on AutoCAD ver. <next year's number>. If we're lucky, it
2009-02-12 07:01 PM
vistasp wrote:I'm not saying it's the truth with a capitol T but it is arguably the most readily available measure of which way the market is heading. Do you have a better metric?
2009-02-12 07:39 PM
2009-02-12 09:32 PM
Chazz wrote:Yep. The Hungarians are just like us Swedes. We're the unquestionably the best, and that's an obvious fact that everyone will see if they just look. So it's best to keep shut. Clam-type marketing works!
I'm with Dwight: "Ignore them and they will go away"
2009-02-13 01:11 AM
2009-02-13 04:19 AM
laszlonagy wrote:I realize you have to wave the flag for Graphisoft here, and I reeeeally hate to have to be the bearer of a cold splash of reality here, but.....
It is true that Revit is big in the US. But hey, here is graph from Germany, the biggest exporter of the world.
