2009-02-12 06:45 PM
2009-02-13 04:12 PM
2009-02-13 04:51 PM
2009-02-13 07:38 PM
JaredBanks wrote:0% AFAIK add-ons are all platform specific. So unless Autodesk gets a big Mac attack (I hear one of their top guys is a Mac user) and decides to spend the time on a Mac version I wouldn't waste any time on that hope.
Cool. What are the odds that the add-on would work on a Mac?
I'm seeing three scenerios then. One, install Navisworks using Bootcamp and switch over to ArchiCAD to run through windows every time we need to save out. Two, hope that the add-on can be copied. Three, stick with a 3D dwg.1. If you have a powerful enough machine (quad core or better with 4GB or more RAM) the best set up is to make a VM and run AC in Windows for publishing the NWCs. This way it can run concurrent with the Mac session. Note that you have to switch the WIBU key back and forth between the two operating systems. This is no big deal if you are not too troubled by the save/quit notice. If you are truly flush and have a spare key around Parallels can allow each OS to access its own key (VMware seems unable to do this).
2009-02-13 07:48 PM
2009-02-17 11:19 PM
2009-03-21 03:00 AM
2009-03-21 07:12 PM
2009-03-22 05:38 AM
JaredBanks wrote:Ah ... the old Imperial/Metric ...
So how do you fix the 25.4x scale issue?
2009-05-13 11:24 PM
Djordje wrote:You can also open up the 3d DWG in AutoCAD and change the units to Architectural/Inches; that's if you have AutoCAD installed on your machine.JaredBanks wrote:Ah ... the old Imperial/Metric ...
1 inch is 25.4 mm.
2009-09-14 03:52 PM
Djordje wrote:I am struggling with this as well. A colleague of mine is trying to import an IFC file created from AutoCAD Architecture. Whenever it comes in to AC, the scale is off by 25.4 and we are unable to rescale it. The original IFC file has been created by a DWG both in Inches and mm. Either way the scale is off. Any ideas on how to get around this?JaredBanks wrote:Ah ... the old Imperial/Metric ...
1 inch is 25.4 mm.
